I need help securing a small business network.
There are 6 systems (3 pcs & 3 mac), a snapserver and a unix server. At this time each has a static IP address.
The unix server is SCO Unix running an app via telnet that manages the company inventory and accounting. Both users in the company and out side the company access it.
The snapserver is serving a dual function. The webserver portion holds a small static html extranet page (company directory). And the fileserver portion is used for data storage and filesharing between mac & pcs.
I want to add a firewall. Normally, I would just make the pcs and macs use NAT & dynamic IPs and set the Unix box on the DMZ, but the snapserver creates a wrinkle to this plan.... and I have one more wrinkle.
The macs are serviced by a guy in another state. He connects to them via Timbuktu... I don't know if the dynamic IPs and NAT will interfere with the Timbuktu or what. Or if there's a way to set this up and still remain secure.
The firewall is the SonicWall Pro VX...
Can you give me any info or feedback on what I need to do or what to watch for?
Thanks.
Thanks.
