Help me remove adware
TheBarEatsYou
Hello, so today I did something stupid and installed Jewel Quest 3. Now I have addware and who knows what else on my computer. Norton killed the uninstaller, so its not in the list of programs anymore.
I googled and found some websites offering free uninstall tools, but I am highly skeptical of these
I don't have any experience with removing this stuff, other than using sbybot many years ago. It broke my registry so I am nervous about downloading anything.
Thanks if anyone can help.
xgsound
1,374
8
Here is a good start, download from www.bleepingcomputer.com when they have it.
TDSSKILLER
Adwcleaner
Rkill
Mbam
1. Use one and only one anti virus and keep it updated. The free ones are Bit Defender, MSE, AVG, Avira, and Avast.
2.periodically or when there are problems:
a. run tdsskiller – this checks for rootkits and corrects - 3 minutes
b. run ADWcleaner- very fast and effective malware cleaner. scan/ select clean. Requires reboot. - 5 or 10 minutes
3. If problems persist:
a. run rkill – it takes 2 or 3 minutes to start and 3 more to finish DO NOT REBOOT
b. when rkill finishes, run Malwarebytes a full scan and fix all - 1 hour or so.
This should fix most if not all the adware. You may also need to reset each browser you use.
Jim
TheBarEatsYou
Thank you so much for your help, xg. I already did a full system scan with Norton. I will try the rest of your suggestions.
For resetting the browsers, do you mean un-install and re-install them? Or is there a simpler way of doing it?
Thanks!
dfgy
Hey,adware is a type of malicious software that can be removed with some anti-virus programs or with programs that are anti-spyware and adware. If you can't uninstall the program, you can try to use third party software, which can help you to removing the stuff.
sbpromania
265
www.sbp-romania.com
Hello,
I recommend using the following tools for removing the adware:
- Ccleaner
- Bitdefender Adware Removal Tool for PC [free]
- Spybot-Preventor
- SAS (SuperAntiSpyware)
- Malwarebytes - Remover
Or you could do a system restore before the date you have installed Jewel Quest 3
Charlotte333
Hey, I suggest you run a scan of the PC by using the free version of Malwarebytes. Malwarebytes is a reliable anti-malware program and it can detect and remove adware and other cyber threats. I have used it for a long time and my PC runs well.
If you know the exact name of the adware, you can follow the instructions mentioned in the posts below to manually delete the adware from your PC manually.
http://www.askvg.com/how-to-complet...-in-windows-without-using-3rd-party-software/
http://guides.uufix.com/how-to-remove-enter-voyage-from-your-pc-uninstall-guide/
