- Apr 21, 2001
- 1,197
- 0
- 0
I'm looking for software to help calibrate my monitors colors and I remember using one before but I don't know what it's called or where I got it, I'm hoping someone can help me remember where I got it. I believe it was bundled with something I bought, but I don't know what. I remember that in one of the tests you would see a shadow of a monste and you had to make the shadow in the bad invisible by turning down the brightness. The rest of the tests were with trying to find which square of red, green, or blue matched with the background. I also remember that when you install it, it became part of the display properties. Does anyone remember it? If not, can you suggest an alternative program? Thanks.
