help me quiet my socket 604 xeon's
fuentefan
Is there some other HSF that will fit this socket that will be quieter than the 5000 rpm stock HSF's??? This thing is totally annoying me.....
Help
Yes. The two that I have used so far are the Swiftech MCX604's, but they are incredibly expensive, and that all that great on performance. They work most definitely, but I replaced them with the Thermalright SI-9XV's. They were cheaper, easier to install, and the performance is great on them. And I didn't think they would fit on my mobo (Supermicro X5DAE), but they fit perfectly.
I advise getting one (or two, if you are running duallie) Thermalrights, a fan controller, and two good Delta Triple Blade fans. Works wonderfully. 🙂
there were some 100% copper heatsinsk i saw on newegg before... take a look there.. btu you would need to buy a fan
