Here's what I have so far:
Intel P4 800Mhz FSB 2.6Ghz @3.26GHz
EDIT: I had to drop my original O/C from 3.26 to 3.13Ghz 'cause I wasn't getting the onboard audio to work correctly
ABIT IS7
3x - ThermalTake Smart Fans (Case, 2 intake front, 1 exhaust rear)
StarTech System Blower 32cfm (exhaust rear)
Stock Intel HS and Fan 2500rpm approx.
Current temps idle 42C CPU, 33C PWM, 32C System
I'm not too worried about the temps, cause it goes up to 58C on CPU load (Sandra@10 reps), but I want to make this beast a little quieter (I'm probably exaggerating, since it is definitely liveable)
SpeedFan's ability to kill my CPU Fan and Chipset Fan speeds showed that my stock HSF was the cause of most of my higher pitched noise - I'm getting the rest of my noise through my case's design for airflow (unfortuately my two intakes run right into two metal plates perpendicular to the fans, but nonetheless causing turbulence).
I want to maintain my temps (maybe drop a little more!) but don't want this thing to be a screaming lunatic. I've been looking through reviews and see a few on Newegg - but I'd like to hear what you guys have for suggestions. Thanks!
ABIT IS7
