Help me please!
Shiva
11
I just built my first system (1900+, Asus A7N266-C, maxtor 40GB, gforce3 64MB) and I'm running XP pro. My old system is a HP pavillion w/a PIII that came with Win 98 installed, a second edition upgrade cd and the HP system cd with all of the pre-loaded software.
My question is can I remove that version of windows 98 so I can put it on my new system? I have a older flight stick set up that wont work on XP, so I wanted to partition my HD and use both OS's. Thank you for any input you can provide.
Shiva
11
What if you had other games that worked better on Win 98 too.....would you invest the $100 to by a new copy on Win98?
jmatt
125
After partitioning , you will need a bootmanager .
Then hook up your old HD into the new system , you can just let it hang down the side , no need to bolt it in & transfer your files using xxcopy .
Make sure you set it to Slave .
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q255867
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q221829
http://www.pcguide.com/proc/setup/hdd-c.html
http://www.webdev.net/orca/nojava/fdisk.htm#Why%20not%20just%20use%20"Fdisk"?
http://www.geocities.com/SiliconValley/Hills/5220/fdiskformatr.html
http://www.hardwarecentral.com/hardwarecentral/tutorials/42/1/
http://www.geocities.com/budallen98_98/harddisk.html
http://www.everythingcomputers.com/reformat_print.htm
http://personal.picusnet.com/jtmurphy/fdisk.htm
http://www.techtony.com/main.htm
http://www.xosl.org
Extended Operating System Loader (XOSL) is the world's only
full-featured free boot manager with a real, easy-to-use and
full-blown graphical user interface. Click the screen shots
link to see what XOSL is like, and decide for yourself!
DOS graphical multi-OS multi-boot manager supports all flavors
of DOS, MS Windows 9x/NT4/2000, Linux, BeOS and Solaris, can
boot from CD-ROM.
xxcopy ( freeware ) from ,
http://www.datman.com/xxcopy/betatest/
Start > Programs > MS-DOS Prompt .
Copy the 1st line below & click paste in MS-DOS & click Enter , you
get a copy of everything . No need to close any programs down .
2nd line excludes Windows .
3rd line copies Windows only .
Adjust drive letters to suit .
XXCOPY C:\ D:\ /CLONE
XXCOPY C:\ D:\ /CLONE /Xwindows\
xxcopy "C:\windows\" "d:\windows" /CLONE
http://members.tripod.com/~diligent/harddisk.htm
Use the startup disk to boot the computer and when you are at the A:\
prompt type sys c: and press Enter. The required boot information will
be copied to the new disk and you have a working copy of the old hard
disk .
