help me please!!! AWWW!!
jkellynewyork
344
I neeed to get this compute built by manana. When I try to boot something up in the CDROM it says a kernal32.dll file is missing and then another message pops up saying that the device attached to this system is not functioning.
I have my hard drive as master and a burner as slave in primary. Then I have my CDROM as master on secondary.
ANy ideas please help, I will try research now but I really need a quick fix for this one I must move on cause I know other problems will pop up.
Dan
What OS are you working with and are you doing a clean install to a bare drive?
And this is unrelated to your current troubles, but I'd set up the burner as the secondary master and the CD-ROM as the primary slave. That way your two data sources (HDD and CD-ROM) are on a different channel from the burner. You'll have better performance.
Mday
18,647
i recommend dan's set up as well.
what do you mean by "when i try to boot something up in the CD-ROM" ????
do you mean booting from the drive, or putting a disc in the drive?
the kernel32.dll error is a very vague error, lots of problems can cause them ;-)
a general fix is a reinstallation of the operating system.
are you overclocking? using an abnormal PCI bus speed?
you're local, um, if you really need help, i offer my personal services as i am bored out of my mind.
jkellynewyork
344
oh sorry I forgot I posted this.
Everything is fine now. I changed to the set up you recommended and it just works. Thanks.
Mday i am in downtown brooklyn were are you at.
