Help me Ping
splice
1,275
Hey guys,
I'm looking at setting up a colocated game server in Colorado at Level3's datacenter and I was wondering if you could help me out.
If you could: ping ns1.Denver1.Level3.net a couple times and report the ping average, your city/state, and ISP.
Thanks for the help! :D
slycat
5,656
Pinging ns1.Denver1.Level3.net [209.244.4.104] with 32 bytes of data:
Reply from 209.244.4.104: bytes=32 time=60ms TTL=237
Reply from 209.244.4.104: bytes=32 time=120ms TTL=237
Reply from 209.244.4.104: bytes=32 time=70ms TTL=237
Reply from 209.244.4.104: bytes=32 time=50ms TTL=237
Ping statistics for 209.244.4.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 50ms, Maximum = 120ms, Average = 75ms
sanfrancisco, CA. Pacbell/SBC DSL.
KLin
30,657
895
Reply from 209.244.4.104: bytes=32 time=108ms TTL=239
Reply from 209.244.4.104: bytes=32 time=88ms TTL=239
Reply from 209.244.4.104: bytes=32 time=73ms TTL=239
Reply from 209.244.4.104: bytes=32 time=86ms TTL=239
Hanford, CA over a 1.5 mb/sec Frame Relay connection
bradruth
13,479
Reply from 209.244.4.104: bytes=32 time=72ms TTL=241
Reply from 209.244.4.104: bytes=32 time=71ms TTL=241
Reply from 209.244.4.104: bytes=32 time=70ms TTL=241
Minimum = 70ms, Maximum = 72ms, Average = 71ms
Grand Forks, ND UND Campus connection.
loup garou
35,132
Reply from 209.244.4.104: bytes=32 time=64ms TTL=244
Reply from 209.244.4.104: bytes=32 time=66ms TTL=244
Reply from 209.244.4.104: bytes=32 time=65ms TTL=244
Minimum = 64ms, Maximum = 66ms, Average = 64ms
NY,NY TWC RR Cable.
Bth47
25
Reply from 209.244.4.104: bytes=32 time=80ms TTL=243
Reply from 209.244.4.104: bytes=32 time=84ms TTL=243
Reply from 209.244.4.104: bytes=32 time=56ms TTL=243
Reply from 209.244.4.104: bytes=32 time=71ms TTL=243
Minimum = 56ms, Maximum = 84ms, Average = 72ms
Columbia, MO, Mediacom
cpals
4,494
ping from my server:
root@server [~]# ping ns1.Denver1.Level3.net
PING ns1.Denver1.Level3.net (209.244.4.104) 56(84) bytes of data.
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=1 ttl=249 time=15.3 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=2 ttl=249 time=15.4 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=3 ttl=249 time=15.3 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=4 ttl=249 time=15.8 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=5 ttl=249 time=15.4 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=6 ttl=249 time=15.4 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=7 ttl=249 time=15.2 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=8 ttl=249 time=15.1 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=9 ttl=249 time=15.3 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=10 ttl=249 time=15.1 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=11 ttl=249 time=15.2 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=12 ttl=249 time=15.0 ms
64 bytes from ns1.Denver1.Level3.net (209.244.4.104): icmp_seq=13 ttl=249 time=15.2 ms
--- ns1.Denver1.Level3.net ping statistics ---
13 packets transmitted, 13 received, 0% packet loss, time 12164ms
rtt min/avg/max/mdev = 15.050/15.328/15.877/0.263 ms
ping from my computer:
Reply from 209.244.4.104: bytes=32 time=97ms TTL=242
Reply from 209.244.4.104: bytes=32 time=101ms TTL=242
Reply from 209.244.4.104: bytes=32 time=99ms TTL=242
Minimum = 97ms, Maximum = 101ms, Average = 98ms
tranceport
4,168
www.thesystemsengineer.com
U:\>ping ns1.Denver1.Level3.net
Reply from 209.244.4.104: bytes=32 time=47ms TTL=241
Minimum = 47ms, Maximum = 47ms, Average = 47ms
U:\>
Lake charles LA 70601
Cox Communications
Twista
9,646
TextMicrosoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\>ping ns1.Denver1.Level3.net a
Bad parameter a.
Reply from 209.244.4.104: bytes=32 time=39ms TTL=243
Reply from 209.244.4.104: bytes=32 time=41ms TTL=243
Reply from 209.244.4.104: bytes=32 time=40ms TTL=243
Minimum = 39ms, Maximum = 41ms, Average = 39ms
Text
Pepsi90919
Originally posted by: CobraBubbles
hey cpal, where those machines located and what type of connections are they on?
apparently someplace where you need root to run something like ping.
Reply from 209.244.4.104: bytes=32 time=87ms TTL=239
Reply from 209.244.4.104: bytes=32 time=97ms TTL=239
Reply from 209.244.4.104: bytes=32 time=71ms TTL=239
Reply from 209.244.4.104: bytes=32 time=90ms TTL=239
emmpee
1,100
avg 56ms, Rochester NY, RIT campus network (100mbit link on a ridiculously fat pipe)
Alkaline5
801
Reply from 209.244.4.104: bytes=32 time=53ms TTL=239
Reply from 209.244.4.104: bytes=32 time=54ms TTL=239
Conyers, GA
BellSouth DSL
dum
352
Pinging ns1.denver1.level3.net [209.244.4.104] with 32 bytes of data:
Reply from 209.244.4.104: bytes=32 time=59ms TTL=246
Reply from 209.244.4.104: bytes=32 time=61ms TTL=246
Reply from 209.244.4.104: bytes=32 time=60ms TTL=246
Minimum = 59ms, Maximum = 61ms, Average = 59ms
greenville, sc ---> earthlink dsl
Rogue
Banned
Jan 28, 2000
5,774
C:\>ping ns1.denver1.level3.net
Reply from 209.244.4.104: bytes=32 time=52ms TTL=245
Reply from 209.244.4.104: bytes=32 time=47ms TTL=245
Reply from 209.244.4.104: bytes=32 time=46ms TTL=245
Minimum = 46ms, Maximum = 52ms, Average = 47ms
Cox cable, Kansas.
splice
1,275
overall pretty good results so far, except for cpals :| cPals, is your server in Florida?
aircooled
15,965
Reply from 209.244.4.104: bytes=32 time=55ms TTL=242
Reply from 209.244.4.104: bytes=32 time=56ms TTL=242
Reply from 209.244.4.104: bytes=32 time=54ms TTL=242
Minimum = 54ms, Maximum = 56ms, Average = 55ms
Earthlink Cable (through Time Warner) Raleigh NC
cpals
4,494
What do you mean?
My server had the best pings of all the ones posted here. Make sure you look at the "time".
CobraBubbles:
My server is located in Texas (ThePlanet) with 8 GigE connections. ;)
My personal computer is located in Florida... just on a 512/128 DSL line.
cpals
4,494
I was already logged into the server already and decided to help the guy out. Is that so wrong? I've used root for as long as I can remember and haven't had any problems. I know I should probably setup different user accounts, but I don't feel like it right now.
If the remark wasn't meant how I took it, then disregard the message above...
Crusty
12,684
Reply from 209.244.4.104: bytes=32 time=67ms TTL=241
Reply from 209.244.4.104: bytes=32 time=35ms TTL=241
Reply from 209.244.4.104: bytes=32 time=36ms TTL=241
Reply from 209.244.4.104: bytes=32 time=46ms TTL=241
Minimum = 35ms, Maximum = 67ms, Average = 46ms
Austin,TX RoadRunner
