Help me ping a little laugh a little.
Dantoo
1,188
There seems to be a little problem with speed tonight.
My pings are ranging from 235 to timing out after 5000. Is the anyway to keep the window open after running the command from the command line other than pause/break?
Is there a better way to run it?
Amuse yourself by pinging back to 203.134.116.114 :p
I'll only be on for another 20 mins though.
Sloth
243
You can open a dos box and run it from there. That way the info stays up till you close the window.
S.
nukefarmer
351
ok then :)
C:\>ping brains.dantoo.au
Pinging brains.dantoo.au [203.134.116.114] with 32 bytes of data:
Reply from 203.134.116.114: bytes=32 time=1070ms TTL=118
Request timed out.
Request timed out.
Reply from 203.134.116.114: bytes=32 time=1130ms TTL=118
hmm, it seems to be there, but not responding very well.
maybe you need a reboot :p
Dantoo
1,188
"A nerve impulse fired in your brain. Your brain needs to be reset now. If you continue working all work will be lost! Shut down all thoughts you are having and restart?"
[YES][YES]
:p:p:p:p:p:p
