Help me pick!
firehawk68
23
I'm buying a new pc, a 1500+ xp cpu+256mb ddr ram and either kyro2 videocard or geforce2 ti, which motherboard should i choose to it? I can't find any info on these motherboards. these are the ones available for me:
AMD: DFI AD70-SC 266A DDR
AMD: DFI AM36-EC
AMD: ECS K7S5A DDR LAN
AMD: ECS K7VZA-266
they're all about $100 here (sweden) any comments welcome since i know nothing about motherboards... oh another thing, is the inbuilt sound on some motherboards anywhere near sb live! 1024? or should i go with a separate soundcard?
thanks.
vampiro
314
You might want to look at the IWill XP333. It seems to really smoke on the benchmarks and is priced at $99 at Newegg. Personally, I would spend a little more to get a Dragon + but that is up to you.
firehawk68
23
thanks but im based in sweden, so i'm unable to do that.
i might consider one of the following motherboards as well IF they include a soundcard that is equal to soundblaster live! 1024 bulk/value (which alone costs about $50 here)
is there such motherboards available? let me know.
these are some of the more expensive motherboards i can choose from, but only if they include the above soundcard quality:
EpoX EP-8KHA+ VKT266A DD
MSI K7T 266 Pro2
MSI K7T Turbo2
DFI AD70-SR Raid VIA266A DD
otherwise i have to go with one of the cheaper ones i originally listed about $100 or so...
Jayczar
1,628
The ECS K7S5A will work great with that hardware.
Go for it!! Regardless of what other replies you may
get in this thread or any other.
Bobek
55
MSI K7T 266 Pro2 is a great motherboard, but as well as others listed it won´t deliver the same quality as the SB Live! soundcard, they simply have only stereo speakers output.
ECS K7S5AL is a good choice, I already had 4 or 5 of them in my hands - good performance and stability, no serious issues. Only one little thing - Win 98SE report some problem with the audio codec on one of the boards I had, but it works fine :)
