Tweak155
Hello all
I received a gift card to Best Buy so was looking at the options they have there. I currently have an I5 3570K setup so I'm still debating if I should even upgrade all my components... what makes it semi-tempting is my 3570k system can replace my wife's aging I7 920 system that I gave her when I got my 3rd gen system lol.
Anyway, I found this as it's on sale and only a little more expensive than competitors:
http://www.bestbuy.com/site/msi-z17...ket-1151/4832512.p?id=bb4832512&skuId=4832512
Seems to hit all the key features I'd be looking for... M.2 slot, SLI, RAID if I end up not going M.2, USB 3.1 and GB LAN.
I guess the biggest question I have is about the M.2 slot... are desktop mobos like laptop mobos where the M.2 slot can be SATA or PCIe? MSI's page doesn't seem to specify, but I'm sure I could look through the manual if I need to.
The second question I can't seem to figure out by looking between different boards is the support of 2133mhz vs 2400mhz. Looks like native DDR4 speeds will be 1 of these 2 variants and it seems like I should go for the 2400mhz variant.. is this even something you have to look out for these days? The mobo I linked only shows (OC) once you go past 2400mhz so it seems like it natively supports either 2133mhz or 2400mhz without any overclock. It's been a while, but the memory speed is no longer tied to the CPU speed, right?
I've been out of the game too long... any info would help or suggestions.
Thanks!
Thanks!
