help me pick out a psu
CheesePoofs
3,163
We are very sorry, the page that you requested does not exist.
You may have used an outdated link or may have entered the address (URL) incorrectly.
Don't be discouraged, Newegg.com offers over 10,000 products, please try using our site search or category listings to find the one that you are looking for.
zakee00
1,949
dont get THAT antec, if you are getting an Antec get a TruePower. they are like $30 more, but they have 2 fans, fan controlers, 2x 12V rails, etc. much better then the regular series. check out enermax also, good stuff.
Operandi
Originally posted by: xS
Originally posted by: Operandi
Seasonic
Does this compete with PSU's made by Fortron, Enermax, etc...
Posting a message along with the link may prove to help answer some of these inevitable quesitons...
Seasonic is defiantly better then Enermax and just as good as Forton if not marginally better.
Kevin1211
1,582
i posted the same message at hardforums and got this response:
seasonics are good supplies, but we arent there yet
I assume you have an optical drive of some sort, CDRW or DVDRW right?
the figures for the 6800GT
http://www.xbitlabs.com/misc/picture/?src=/images/video/ati-vs-nv-power/6800gt_table-b.gif&1=1
most of the rest would be on the http://www.abit-usa.com/produc...egories=1&model=80]mobo[/url] and not seperate equipment, I gave you 3 case fans and a big fan on the CPU (high draw not physical size)
http://takaman.jp/D/?M=PcQORNSCkG5DrYcZAZbOP&english
or a theoretical maximum of
+3.3V @ 2.5A
+5V @ 9.3A
+12V @ 18.4A
286 Watts
in this case we can skip the spinup draw baseline and proceed diectly to a realworld worse case senerio
+3.3V @ 2.5A
+5V @ 9.3A
+12V @ 16.4A
about 250 watts
with all the fans, the HDD at 25% draw
the CPU, AGP, mobo and a single optical spinning up at 100%
since most supplies are rated at an artificailly low temperature you cant replicate
they need to be derated
so Id recommend at least a 400 watt supply with a minimum of 26 amps on the +12V rail
but in truth it would be far better for you to get a supply that meets the latest spec ATX12V v2.0
which will have a 24 pin main power connector (and an adapter if your board is 20 pin which it is) they generally have 30A on the combined +12V rails
an entry level supply would be the
http://www.newegg.com/app/View...=17-104-934&depa=1]Fortron Blue Storm[/url]
there are several Enermax ATX12V v2.0- supplies, there is also the Antec Neopower
total wattage is from 470- to 500 watts and would provide you with some expansion room and a safety margin ;)
thoughts?
Operandi
+3.3V @ 2.5A
+5V @ 9.3A
+12V @ 18.4A
286 Watts
+3.3V @ 2.5A
+5V @ 9.3A
+12V @ 16.4A
about 250 watts
thoughts?
Dosn't make much sense to me.... 26A min... :confused:
