randomlinh
Originally posted by: jpeyton
The 18-55IS should be fine for landscapes and people. That isn't enough reach for animals, unless they happen to be in a cage or petting zoo.
that's why it gets coupled w/ the 55-250IS =)
Unless the 55-250IS isn't in your budget. In which case, you downgrade your body to the next lowest model (in this case the XSi) with a two lens kit.Originally posted by: randomlinh
Actually, in regard to pure image quality, the XSi is every bit as good (and in some high-ISO situations even better) as the T1i. The difference between 12MP and 15MP in real-world use has very few advantages and several disadvantages.
Of course, the XSi doesn't have a movie mode nor does it have a VGA screen. Two things that really don't matter when it comes to taking great pictures.
We'll get more pixels year after year; that is an inevitability.Originally posted by: magomago
It makes me wonder how high of a pixel density we will push on APS as each generation adds more and more.
But we're seeing diminishing (and even negative) returns as a result.
Camera technology is advancing slower than the yearly rat race for pixels. Even though Canon may want to release a camera 12 months from now with 30% more pixels in the same sensor area, they may not have the technology to improve image quality for 24-36 months.
Is 15MP too much for an APS-C camera? No. But Canon's 15MP efforts so far have been rushed; I'm sure their next generation of 15MP cameras will fix some of the noise issues with the T1i/50D.
Originally posted by: Agentbolt
So much for that. After actually playing with one at Ritz, I ended up grabbing a Rebel T1i. I know, right? Not even kind of what I was looking to spend before. God this thing is sweet though. It does come with the standard kit lens, which is probably gonna be holding back its performance a bit, but if I end up getting super into this whole photography thing, I can always spring for a better piece of glass.
FWIW, I think photography is actually a relatively inexpensive hobby. Certainly, the startup costs can be teh suck. But a well cared for body and a couple decent lenses will continue to perform as well as they did since day one for years and years.
Compared to....say...persistent bike maintenance.
(or winter skiing in my case).
I've been wanting to upgrade my EOS 300D (original digital rebel) for years, but the fact is that picture quality and camera performance are still quite adequate for my usual needs...so I just can't justify the cost. *sigh*![]()
Man bike maintenance strikes me as being cheap in comparison. If I get into this big-time, I'm going to need more lenses, not to mention a better computer to mess with the images, and I'll also need a flash, filters, wide-angle adapter, etc etc...
My bike just needs new tubes and brakes every once in awhile![]()
But what I'm saying is that with stuff like quality lenses, it's essentially a one-time purchase. I've got 40 or 50 year-old Pentax screw mount lenses that work spectacularly.
Camera bodys, Lenses, flashes, tripods, monopods, filters, camera bags, Umbrellas, lightstands, and of course printing add up pretty quick. And as mentioned, a nice PC w/lots of RAM, software (LR is $299, Photoshop is $699), large HDD, and backups of HDD aren't cheap.
And quality lenses aren't as cheap as they used to be, the top of the line lenses contain image stabilization ,fast AF motors, and weather sealing.
I remember when I first looked into a DSLR, I thought the first cost of just the body+kit lens was steep (even entry level), but that was just a drop in a bucket.
Now I'm not saying that biking is cheap, I just don't see a bike accessory costing $10,000.
where did you see this information about noise problems with the T1i? I checked all the major review sites and none of them mentioned this. They did all say it doesn't take BETTER pictures than the XSI, nor did I really expect it to. But I saw nothing about horrible noise issues with the T1i, either compared to relevent Nikons/Pentaxes or the XSI
Canon is doing something weird with the T1i's chroma NR.Originally posted by: Agentbolt
Here is the Imaging Resource studio scene at ISO 1600. Check out the red fabric on the fabric wheel (at the 3 'o' clock position):
T1i ISO 1600
XSi ISO 1600
Canon's reach exceeds its grasp.
T1i ISO 1600
XSi ISO 1600
Originally posted by: aphex
So i'm still torn..... K2000, XS or XSI.... Hrmph
I think I may just go all in and grab the K2000 with kit lens for $419, its just too good of a deal to pass up
Actually, I've gone back and forth 1000x on this decision and I just can't say yes to the Pentax in the end. Two big things are keeping me away, no user selectable focus points and the upgrade path. I'm just not a big fan of the higher end pentax models while I am with Canon and Nikon.
I think I'll hold out for a good XS/XSi or D3000 deal. Get a low end body for now with decent glass, then worry about a more advanced body down the road.
Originally posted by: munky
Look at the RAW noise tests here - http://www.dpreview.com/reviews/canoneos500d/page15.asp
Without any in-camera processing and NR, the T1i has higher noise levels than either the XSi or the d5000.
Originally posted by: arrfep
If you want to go Canon, I'd pick up an Xti, $349. It's cheaper than any other Canon right now. I've bought a refurbished DSLR from Adorama and it was indistinguishable from new. At this price, you can pick up a kit lens and a tele-zoom like the 70-300mm and stay under $500 total........My last recommendation is an Olympus E-450 2 lens kit, $469.95.
