Hello!
I currently have a FTTH connection that I just upgraded to 1Gb/750. The integrated modem / router is okay, but I am thinking of bypassing it and using something that will deliver better speeds. A lot of the routers seem geared to long-range, as opposed to dealing with a smaller urban environment with a lot of competing signals. My service is with Bell Canada, and I'm currently just using the provided HH3000 (Home Hub.)
Thank you!
- I live in a condo (it's a one-bedroom and den about 550 square feet.) Lots of wifi signals to compete with.
- I have a ton of things connected: a bunch of Philips Hue lights and hub, computer, tablet, phone, smart watch, smart scale, smart TV, Apple TV, Nvidia Shield, Roku, Google Home, couple of HomePod speakers.
- Needs to support pppoe without any issues as that's how I would by pass the HH3000.
- The modem is in a media closet in a closet near the front door / den are. The new router will go in the closet.
- The condo is basically a rectangle in shape, with the den and foyer being an add on so essentially an L shape.
- I would like to keep to around $200CDN unless there is something outstanding for what I need, then I can consider spending more.
- TP-Link Archer AC3150 v 2 - was about to buy this, but they only had the older version at the store I was at.
- Asus AC86U - it's more expensive than the Archer.
- Portal Wifi - I found this interesting, but the implementation didn't leave me with much confidence, as well as the long-term support.
- Eero - I like the simple look of this, but seems the max speeds wouldn't be better than what I currently have.
- Google Wifi - would be fine except it doesn't perform at a fast enough level.
Thank you!
