- Feb 22, 2008
- 2,846
- 4
- 81
I bought a 21.5" acer H214H monitor a year or two ago, and I'm thinking about upgrading to a 27". The monitor is okay, but my biggest issues are with gaming.
here it is if you wanna check out the specs: http://www.newegg.com/Product/Produc...82E16824009157
I think it must have a crappy viewing angle from above and below, because staring straight at the monitor, the bottom and top are both bleeding light pretty badly.
In addition, if im playing a darker map, I have to tilt it down so i can distinguish where people are. So im not sure if this has to do with a bad viewing angle, or crappy contrast.
I also sometimes experience a flickering when the screen gets dark when playing my 360 over HDMI.
So obviously I want a bigger monitor, but when picking a new one, things i am considering are:
LED? - I am guessing LED LCD's are a little bit better, and will be brighter and have a better contrast ratio, so should I go with LED?
3D - not a huge deal to me, but if its only a little more, id like to have the option. I will be playing xbox on this, and i heard some games are 3d capable. Also a note on 3d monitors - is this the same as a 3d tv? or are there different versions? I've seen nvidias 3dvision, and also regular 3d stuff. I havent really looked into it, but id like the option for the future.
Contrast ratio - very important to me for games.
res - 1920*1080 is probably fine for me, I've seen some higher res screens, but they were much more expensive.
taking those factors into account, I was considering this monitor:
http://www.newegg.com/Product/Produc...82E16824005203 but I really havent looked around that much, because im not sure what I should be looking for.
What do you guys think?
