<< Get the MAXTOR 60GB 7200RPM non-ATA133 model... you dont need ATA-133 anyways... >>
Which drive are you referring to?
All of the Maxtor drives he listed were of the D740X series, and hence all of them support ATA133.
Unless your referring to an older generation maxctor 7200RPM drive, though he didnt mention any.
Of the drives listed I'd personally go with the D740X 60GB from NewEgg, unless your quite concerned about noise in which case the D740X "quiet drive" from NewEgg... more properly known as the D740X with fluid dynamic bearings is a fine choice, though the FDB D740X's seem to have a slightly higher RMA rate then the typical ball bearing D740X drives.
As for Western Digital, I consider the 60GB D740X a better drive then the WD600BB. Comparative overall speed, with a better seak time on the D740X, and slightly quieter.
Neither drive has shown themselves to have unusually high RMA rates, soo nothing to unduly worry over there.
