zCypher
Hello,
I have an E5200 right now. I've never been able to overclock it with my MSI G31M3-L V2 but I was always relatively happy with it nonetheless. Anyhow, I've often been running Prime95 and checking my temperatures with HWMonitor. Depending on the type of test run I get different results. Using the FPU torture test, I saw my CPU temp go as high as 68c. This is pretty high I think. The other test (mixed, lots of ram) did not exceed 58c for CPU.
So, were I able to, I'd probably play a bit with overclocking but it's really not a big concern for me. Mainly I want to make sure that my temps at the current stock 2.5GHz stay low. I was happy with 58c but 68 seems a bit much.
What do you recommend?
MOD EDIT: Moved to Cases & Cooling. - Zap
