Originally posted by: michaels
In what ways? For riding around the neighborhood that would justify the difference in price.
It's not just the price of the bike that makes a difference, it's where you buy it. A $300 bike from Wal-Mart would still to be much worse than a $300 from a local bike shop (LBS), a small shop that specializes in high end bikes. This is because an LBS has professional bike mechanics build and TUNE the bike properly instead of some part time teenager at Wal-Mart.
Once you ride a bike with a high quality frame and components, you can tell the difference the second you start pedaling, but it's probably not worth the price difference if you are just riding a couple miles a week or if you live somewhere where it's likely to get stolen. If you ride at least 30-1hr a week, I would definitely recommend an LBS bike.
Here are my observations of LBS bike vs. department store bike:
First of all, usually they ride a lot smoother since they are tuned properly and it's more comfortable if you buy the correct sized frame (Wal-Mart bikes only come in one size). The bike is more stable and absorbs the shocks and vibrations from the road much better because of the better frame/fork and better construction. Also, all the components just feel like they're quality is much better. When you brake everything just works smoothly and isn't too loose or too tight since the brakes are properly adjusted. Every bike I've gotten from Wal-Mart has had the brakes WAAAY too loose. When you shift, the shifters usually click into place nicely and the bike changes gear IMMEDIATELY instead of rubbing on the chain for 10 seconds before actually changing.
There's also the weight of the bike, I can lift my $350 hybrid (mountain bike frame with road bike sized wheels)
comfortably with 3 fingers. I have to use my whole hand to comfortably lift a bike from a department store.
Suggestions for the OP:
Since there are hundreds and hundreds of different used bikes out there, it's hard to suggest anything specific.
However here are some bikes to get you started. I'll just suggest Trek since it's probably the most widely available high end bike brands and they seem to offer a lot of cheaper bikes, you can look around for similar bikes from other brands.
If you plan to ride off road or just like fat mountain bike tires (which are slower but more comfortable on the road), you can get something like a
Trek 820. The MSRP is $290 but bike shops usually sell them for a lot cheaper especially when they're trying to get rid of the previous year's models.
Any of the following bikes can be used in dirt roads and paths as long as you're not doing jumps or anything.
For a couple hundred more you can get a hybrid/commuter bike, which is usually a mountain bike frame with flat handlebar and road bike (700C) tires instead of 26" mountain tires. They're much faster and more efficient on the road, I personally have the
Trek 7.2FX.
The
Trek 7100 is a bit more on the comfort side of hybrid bikes, it has a more upright position and a front suspension, it's also cheaper.
Comfort bikes like the
Trek Navigator have mountain bike sized wheels, but with less tread. They're a lot more upright sitting position and have front and seatpost suspension.
Find a category of bike you like and shop around for bikes from different brands like Specialized, Schwinn, Giant, Diamondback, GT, Gary Fisher, etc. Used bikes are usually the best deals, but sometimes the sizing isn't right and its usually just nice getting a brand new bike that's not all scratched up and stuff. Also don't forget to test ride first, bike shops pretty much always offer free test rides whether you're actually buying or not.
btw sorry if there are misspellings grammatical errors. I didn't proof read.
