Help me pick a case
mlk3454
301
Hello, I am looking to build a new comp and of course need a new case for it. The only requirements that I can think of would be 120mm fans, usb/sound/firewire up front, and the size of a midtower. I just missed the Antec P160 deal and I am a bit mad because that had all that I was looking for. I dont care for looks and my price range is under 100 bucks. I am looking at a few 500w PSUs so it doesn't need to come with one. Any suggestions? Thanks guys!
mlk3454
301
Thanks for the quick help guys. The 500W is probably over-kill but I have a 6800GT, a couple DVD drives, 2 hard drives, a couple more fans just in case and an athlong 64 3500+. I would rather have some extra "juice" than hit the wall. As for the cases these are great. Are there any more that can be thrown in the round-up before I pick? Thanks again! :D
Operandi
For the prce the SLK3000 is one of the best cases you can get with 120mm fan mounts.
A good 350 watt PSU will run your system with power to spare, don't waste money on a 500 watt PSU.
mlk3454
301
Ok, this should be one of the last questions. The difference basically between the Antec SLK1650 and SLK3000 is the size of the case. Seeing that I have 2 optical drives, 2 hard drives, a floppy drive, a full size atx case, etc to go into it; which one would be the smarter buy?
Mucker
2,833
The 3700AMB is very nice too for $65 shipped: http://newsite.pagecomputers.c...amp;product%5Fid=58617
I built 2 machines with these cases. Has the 350w PSU, a place for two 120mm fans (1 included), rubber mounts. It is very quiet with very good airflow. Outstanding case. Even does a better job at hard drive cooling than the 3700BQE or Sonata (the front 120 blows air directly onto the drives). Best of luck......
m :)
