- Mar 16, 2005
- 44
- 0
- 0
I am planning to partition my new 74GB Raptor like this.
C: 2GB for DOS(FAT32)
D: 6GB for OS(NTFS) -- Per sonoma1993 suggestions
F: 30GB for Apps(Photoshop, Flash MX etc.) (NTFS)
G: Rest Games and Data (NTFS)
Planning to use max of 60GB on this Raptor.
This is how I have come up with this idea:
1. I have checked Internet and found out that I should not fill an NTFS partition more than 85% or the Master File Table [MFT] can become badly fragmented.
2. Having OS installed on a drive other than C: sometimes prevent n00biehackers from affecting it.
3. Having OS loaded near the outer edge of the HDD helps in seek time.
4. Having a FAT32 partition loaded with DOS utilities may come handy on a rainy day.
Q1. Is this a good idea?
Q2. If it is then what is the best way to achieve this? WinXP Partitioning while Installing the OS for the first time? **n00biealert
Q3. Or should I have to use FDISK? If I use FDISK then I believe, I need to install DOS and partition the drive first before installing WinXP. Am I right? Where can I find latest DOS OS and utilities?
Q4. Can anyone give me a walkthrough on this?
Thanks a bunch for all the help..
- Rex
- Rex
