System Specs
Abit KT7 Raid
Athlon TB 850@1GHZ
Super HegeHog HeatSink
128 Crucial Ram pc133 cas 2
CLAP2 32Mb
IBM Deskstar 46.1GB ATA100
Three 120 mm Ys-Tech Fans (Two on side of Pc by PCI Slots) and the other is on top so two blowing air in and one takeing hot air out.
Also got two 80mm ys-tech fans inside pc
I need to go through the settings and overclock this rig.
The only thing l have done since l got my new stuff is gone into the bios and changed the Clock settings from 850 to 1ghz and that is it nothing else.
What l want to do is to make my ram work at a higher speed something like 147 ?? if possiable
And do something with the FSB settings l will need to know what Voltages to Run at etc also what Ram settings to put it on so l can get the best out of my new Rig
Abit KT7 Raid
Athlon TB 850@1GHZ
CLAP2 32Mb
