Hi! I recently planned a HTPC build to use as a client for MediaPortal. As is often the case, the specification (and cost!) has crept up and it's now going to be a Gaming/HTPC in a very small case. The components are as follows:
AMD A10 5800K Black Edition
ASRock FM2A75M-DGS
Samsung 830 128GB SSD
Kingston 2x4GB 1600MHz LV RAM (KHX1600C9D3LK2/8GX)
Scythe Kozuti Fan & Heatsink
Coolermaster Elite 100 Case & 150w PSU (PSU fan replaced with a Noctua NF-A4x10 FLX)
I plan to do a bit of overclocking/underclocking to fit my requirements of a quiet Gaming/HTPC with maximum graphics performance but high efficiency. I've done a small amount of basic overclocking in the past but I need some advice with this.
1. I went for the 100w A10-5800K instead of the 65w A10-5700, because they're the same chip and cost the same, only AMD have undervolted and underclocked the 5700. I thought that if I get the 5800K I can 'make it' a 5700 if I wish but the opposite would not be possible, so it seemed the best option for flexibility. I don't need much CPU performance but I do need graphics performance, so if possible I want to undervolt and underclock the CPU, but increase the graphics core to 1000MHz
2. Apparently the Trinity APU's get a real boost from memory bandwidth. From reviews that I've read the 1.35v Kingston RAM can be overclocked to 1866MHz @1.575v CL9-9-9-27 or (possibly 10-10-10-27 - the review isn't clear) I've read some Trinity reviews where they have set very loose timings on mediocre RAM to get up to 2133MHz and achieved very nice boosts to graphics performance, so if possible I would like to try for the same.
Has anyone done anything similar? Have I made any 'schoolboy errors' in my thinking or are there any other pointers you guys can give me? The final components arrive on Wednesday and I'd like to hit the ground running with this, so any advice will be gratefully received!
ASRock FM2A75M-DGS
