- Sep 4, 2001
- 5,675
- 0
- 0
A group of workers were cutting two fields of hay. One field had twice the area of the other. They all worked on the larger field for a half day, then half of them started on the smaller field the other half of the day. At the end of the day, the larger field was cut, but one worker had to work an entire second day to finish the smaller field. How many workers were in each group?
This problem has gotten me stumped, its geometry and im in 8th grade. you smart ppl here should be able to get me started right? i hope so... i dont need the answer, just like hints on where to start or to point me in the right direction...-_- so hard..
