SpeedEng66
- What YOUR PC will be used for. That means what types of tasks you'll be performing.
and this pc stays on 24-7
- If YOU intend on using any of YOUR current parts, and if so, what those parts are.
pc chips g55 7050/610i
zalman 7k alcu
2 x 1gb ddr2
antec sonata1 + antec 240 watt psu
I
- IF YOU have searched and/or read similar threads.
- IF YOU plan on overclocking or run the system at default speeds.
ok im down to the last parts needed for my new htpc (SD)
A new CPU
im not going to be running hdtv content (at most is 720) because the output is via 480 projector (16.9)
ive been running a pentium m 1.7 2mb l2 and it's been fine (video wise)
and from what Ive been reading L2 doesnt affect media (only gaming)
also vista HP x86 is alittle taxing on the older pentium m so time for a upgrade
so out of these 2 dual core's (e1200 or e2140)
which one would you choose?
(price of the two is not an issue lol $20 difference)
would the celeron be lower in power consumption? (both have speedstep:thumbsup🙂
(just tryin to be alittle greener)
Thanks
