- Feb 7, 2007
- 466
- 0
- 0
First, a disclaimer: The price of the TV as advertised does not matter. The reason for that is because I'm an employee at a store that gets these at a discount price. Just imagine that they're all the same flat rate.
Samsung 61" DLP 1080p Slim-depth (Non LED)
http://www.amazon.com/Samsung-...80p-HDTV/dp/B000N53T82
LG 50" Plasma 720p
http://www.buy.com/retail/prod...d=13450663&dcaid=17902
Toshiba REGZA 47" 1080p LCD
http://www.amazon.com/Toshiba-...80p-HDTV/dp/B000MXYD2Q
The order of price: LG 50" Plasma $1150 > Toshiba 47" LCD $1300 > Samsung 61" DLP $1600.
As far as the Plasma: I know the colors and black levels are way better than LCD's. It's also the cheapest and it's 3" bigger than the Toshiba. I think it's a nice brand too.
The cons are that it has image retention issues and I do game, and it's the only TV out of my choices that's 720p/1080i only. I do plan on watching HD content on it in the future. (I am getting a 60gb PS3 and I have a Toshiba HD-A3)
For the LCD: High resolution. Flat panel just like the plasma. Attractive price point. 1080p means the highest current resolution for my HD media. With ambient lights and during the day I won't get reflections on the screen. Ideal for gaming because of no image retention and the fast response time.
Cons are that it's an LCD and thus has washed black levels even with a high contrast ratio. The other con is that it's the smallest screen so I might have the "go bigger" syndrome. The other con is of course viewing angle, but that's an issue with any TV other than plasmas.
For the DLP: Of course image quality is top notch compared to any other screen. No ghosting effects, highest resolution, best colors, contrast and response time. It's also the biggest screen. Also, as long as the bulb is replaced and the convergence is maintained, the TV could last a very long time. Whereas a plasma/LCD has a lifetime between 45,000 and 65,000 hours.
The cons are that it needs a bulb replacement which runs anywhere from $250 to $350 and it's not flat panel which means it can't be wall mounted. It's also $1600 whereas the other two screens are closer to the $1000 side of my budget.
Now for speakers:
This isn't so much of a, what are my options as it is just me asking your opinion. I move a lot, and there's a chance of a not so big room being what I live in, so these are the speakers I'm considering. I can get them for roughly $220.
http://www.bestbuy.com/site/ol...&cp=1&id=1172882131588
150 watt subwoofer and 5 satellites, one being a center channel. I would be using monster cable navajo speaker wire and a Yamaha 500w 5.1 receiver with DTS and DD and PL2 decoders.
Are they good speakers for a low range system?
LG 50" Plasma 720p
Now for speakers:
