So I currently have:
http://www.newegg.com/Product/...x?Item=N82E16824002129
A 19" NEC 90GX2-BK (just black unlike the link) LCD Monitor.
This product is discontinued and I'm curious as to my best option for running a dual-monitor setup that works well. My biggest concerns are buying something even from NEC and the monitor heights not matching up.
Should I stick to NEC to ensure things look good or will other alternatives work/appear just as well?
Also, if I were to try a widescreen for my 2nd monitor is that just asking for trouble with things lining up? Worth considering?
Thanks in advance.
Thanks in advance.
