Originally posted by: brunswickite
whats the difference, arent they ide as well?
You are aware of the letter N right? Once I can understand but three times in 2 sentences? As for the cd-rom, just pull one from a throwaway you see on the street, or use a USB external if you can.Originally posted by: teh meow
Does anyone know where I can get a apple cdrom or a apple DVD rom? I looked on anandtech and mac.com, but no luck.😉
Yeah, but you need a apple cdrom to boot off a cd.
what...?
where are you getting this info...?
what...?
You do need a apple cdrom to boot off a cd, don't you?
what...?
no...you just hold down "C"
what Mac are you using?
what...?
That doesn't work.🙁
Originally posted by: UlricT
are you asking for a CD Drive or a bootable apple disk?
This thread is heading in the direction of the "solution with crystal" thread
Find your System Software CD that came with your computer and put it into your CD drive. The CD should spin up and your computer should start booting from the CD. If this does not happen, restart your computer (command+control+power key). When you hear it chime, hold down the 'C' key. If it still does not boot, restart again and this time hold down command, option, shift and the delete (backspace) key after you hear the startup chime.
You do not need an "Apple" CD-ROM...any CD-ROM will work...
Not true. Only a select few work. A few old HP's were capable of doing this.
Well, it seems you know which drives will work, so just Froogle those.
