Help me install iSight camera on OS X "Tiger" / VMWare Fusion / XP Pro iMac
mshan
7,868
I have a Core Duo Intel iMac with Mac OS X "Tiger".
I just installed VMWare Fusion with XP Pro.
I want to be able to use iSight camera within virtualized XP Pro, and I think I need Boot Camp drivers. Add/Remove says VMWare tools is installed, but option to install VMWare Tools is still enabled within VMWare Fusion menus.
Since Boot Camp beta is ending for Tiger, is it safe to install boot camp drivers if I don't want to update to Leopad.
If so, how do I do this?
(I installed XP Pro without using Boot Camp, so I would like to completely avoid Boot Camp partition, etc. Just want to run within VMWare Fusion container only).
SoundTheSurrender
3,126
I had the impression that you can activate iSight by just clicking on USB devices and adding it in VMware and Parallels. The same way as adding a USB flashdrive.
