I just threw together what appeared to be well-reviewed parts. I am not very knowledgeable about modern products, and where to find the value. I am sure there are improvements that can be made. My budget is a hard $1200. The main function will be doing 3D renderings in AutoCAD.
Motherboard: ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813131665
199.99
Processor: Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950
http://www.newegg.com/Product/Produc...82E16819115211
294.99
Graphics Card: XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Produc...82E16814150477
229.99
Memory: CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9
http://www.newegg.com/Product/Produc...82E16820145222
119.99
Power Supply: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Produc...82E16817139006
109.99
Hard Drive: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
http://www.newegg.com/Product/Produc...82E16822136533
89.99
Optical Drive: ASUS Black 24X DvD Burner
http://www.newegg.com/Product/Produc...82E16827135204
18.99
CPU Cooler: COOLER MASTER Hyper 212 Plus
http://www.newegg.com/Product/Produc...82E16835103065
Arctic Silver 5
9.99
Total: $1,123.92
Are the aftermarket CPU cooler / thermal paste good to get or unnecessary? Are there better bang for your buck options when it comes to GPU and RAM?
I've swapped some parts out of my PC, but never built one from scratch. Is this everything I will need? (I have OS, keyboard, mouse, monitor, speakers)
199.99
294.99
229.99
119.99
109.99
89.99
18.99
Arctic Silver 5
9.99
Total: $1,123.92
