well it seems that you're lacking a solid format. i'm not familiar with the IT industry, though, so i can't talk about their standards. here's what i would change, but i'm no expert so just consider my suggestions lightly
1) the qualifications section seems superfluous and self-serving. it's easy to say you're dynamic and have leadership skills - prove it by showing examples from previous experience (which you've done to some extent, so it's useless to write it twice.)
2) whoops, did you forget to proofread? "preformed?" (last bullet of MSC experience.)
3) you seem to like using "increased productivity/efficiency." it gets old after a while, and to a reader who takes 30 seconds to scan your resume, it sounds like you're listing the same thing 10 different times, regardless of whether or not it's the same project/accomplishment.
4) try to include an "activities/skills" section to include languages or misc. activites that show exhibit transferable skills.
5) your position as an assistant office manager lacks impact. although it may not have been the most glamoros position, you need to show everything in a positive light. "helped to work on getting the first internet connection to the company" sounds awkward. try, "provided expertise to upper management in preparation for internet connectivity" or something along those lines. your next two bullets could also use some work.
6) you graduated in 2003 - so are you an older individual that went back to school, or are you 22-23? if the former, i'd list some previous experience, even if it doesn't exactly relate to the job you're applying to. employers are always looking for transferbale skills. if you're a recent grad, i'd list some relevant coursework and any activities you had time for, in addition to working full time.
that's all doc. good luck in your job search.
