This may be a dumb question, but why is the interesting part of the die colored? I always assumed the coloring was for visualization purposes and that a fabricated die would be uncolored.
You can remove the metal heat spreader... google "decapping" or "delidding". People generally seem to do that using a very sharp knife around the edges. In my experience, the lid is usually not soldered to the die, although I've seen some Intel CPUs where it was. Don't bother trying to sand/grind through the heat spreader - it's very thick, and the die underneath it is very thin.
Getting a picture like what you posted is relatively difficult. With older wire-bond processors (e.g. 386, 486, Pentium, Pentium Pro), simply exposing the die showed you the "interesting" side of it (see this for an example). However, all modern processors are "flip chip" - instead of connecting to the external world through a ring of wires on the outer edge, the entire surface is covered in small solder bumps that connect to corresponding solder points on the package. If you remove the lid, you'll see the uninteresting side of the die...and I've never managed to get through it from the uninteresting side. Intel's TV commercials show the interesting side up, but that's just not the way the chips are really built. You'll need to remove the die from the package. I've managed to removed dies from packages using a blowtorch to melt the solder. I would imagine the fumes are toxic, so you probably don't want to breathe them.
Here is a photo I took of the underside of a Core 2 Quad after removing it from the package. After sanding it a bit, I got this result, and with some more sanding I finally got this result. Note that it's extremely difficult to sand evenly enough to get good results on modern process nodes. Some areas of the die are exposed down to a very low layer, while others are still covered by higher layers. Here is a photo of a P3. Here is a P4 Prescott (note the diagonal scratches from my coarse sand paper).
So, the steps I've used were:
1. Sharp knife to remove the lid
2. Lots of heat to melt solder and free the core(s) when the solder is molten
3. 600-2000 grit sandpaper
I have many more photos if you're interested. Member idontcare helped me significantly.
My guess is that it's mostly related to the structures being small compared to the wavelength of light. "Color" in the normal sense doesn't really mean much for a wire that's 130nm (0.13um) wide. You'll only see color if you have a lot of those wires next to each other, and then the groupings of those wires could appear different colors based on their patterns (for example, you could build a "red" 650nm structure from the smaller components, or a "blue" 450nm structure.
I've noticed that the color changes dramatically based on the angle of the lighting; fluorescent lighting seems to work best for producing the most impressive colors (possibly because of the more pronounced emission peaks).
CTho9305: do you have any idea why it is more difficult to sand on the area of the die that is exposed after removal of the heat spreader?
I'm also somewhat surprised that a blow torch would not do more damage to the die itself before the solder melted.
Wow, those are great photos. Thanks for sharing 🙂.I have many more photos if you're interested. Member idontcare helped me significantly.
