It ran perfectly for months on the CUBX at 933 MHz. I just got a CUSL2 and can't boot at 133 MHZ FSB. I have the halt on errors set to none. In the bios there is a setting for FSB:SDRAM: PCI Ratio which I set to [133:133:33], then another setting for FSB/SDRAM/PCI Freq. (MHz) which I set to [133/133/33]. Is this the correct way to set these. I see no other way really. Anyway, the machine will not boot into windows with these settings, but does work fine at [100:100:33]. HELP! I think I've tried everything.
