- Aug 9, 2000
- 18,378
- 2
- 0
I have an old gateway 600x that my mom wants.
The LCD will not show a picture, it is so dim. I initially thought the lamp burnt out. I could not check it because I really do not know how to get to the lamp in the LCD. I bought another LCD (pulled from a working notebook), but the problem is not fixed yet. I then proceeded and bought anotherLCD inverter....no go. I do not want to buy a new Flex Cable and find out it is not the flexcable.
I was hoping 1 of teh following was happenning.
1. The LCD lamp is bad (the new LCD does not work, so I guess that's not the case).
2. the replacement inverter is bad (got another one, but that fixed nothing)
3. The flex cable is bad (how easy can these break?)
1 thing I noticed is that when I put a desktop lamp behind the LCD, the LCD shows an image (I guess that means it's either the inveter or LCD lamp?). I have been trying to fix this for 3 months and I am finally thinking about throwing this thing out the window. I am just hoping nothig is wrong with the motherboard.
For history sake, this all began after I replaced the DC jack on the laptop. before hand, it kept shorting because a piece broke off. Everything worked perfect before the DC jack went south.
