- Jan 6, 2002
- 373
- 0
- 71
I currently have my E8400 running at 3.80 GHz (9x421)@ 1.3500 volts, DDR voltage 1.90, NB voltage auto.
I have an Asus P5K motherboard and G.Skill Pie Series 8GB DDR2-8500 5-5-5-15. I also have sufficient cooling, my CPU has Thermalright IFX-14 with 120mm Delta and the memory has OCZ XTC for some active cooling.
I have tried lowering my timings to 6-6-5-18, DDR speeds not breaking 900 usually in hopes of getting the 4GHz (9x450) to load up Vista64 with no luck. I can get it to post with no problems but Vista64 will blue screen right away.
@ 3.90 GHz I can post with no problems but Vista64 will crash when I get to the login screen. Same voltage settings on the CPU and memory as well as the memory timings.
Other specs are:
Antec 1000 watt PSU
Radeon 4850 Crossfire 450 core/1010 mem clocks.
Asus Xonar 7.1 PCI-E
Other specs are:
Antec 1000 watt PSU
