Here's an odd one but I'm not having any luck on my own, so here goes.
I'm looking for a wall unit / bookshelf combo. The catch is, I want to spend < $1000 on it. I am looking for something sort of IKEA-esque, but of decent (not great) quality. The ones I like I keep finding in 'european' furniture stores and they want an arm and a leg.
This is approximately what I'm looking for. Unfortunately, this particular set is $2000+ and it isn't quite right either. I have to get something that will let me wall-mount a 50" TV in the middle. This will probably involve some cutting and rearranging, but I'm ok with that.
Anyway I figured I'd ask if anyone has suggestions. I have found a couple things online and a couple locally, but for one reason or another they never pan out. I like the one above because the whole set is made of 1.5 - 2" thick (fake) wood beams... I managed to find one locally that was very similar for 1/3 the cost, but it had been discontinued by the manufacturer and they couldn't order more...
$10 reward if I actually end up buying anybody's suggestion!
