There are plenty of cards that do either, & they're dirt cheap... The ones that do both are significantly more expensive than two single cards would be.
Someone mentioned that SIIG and OrangeMicro both got good combo cards. I'm planning to buy the SIIG 1394+USB 2.0 from my work place. Just make sure you go to the websites and see if your camcorder is compatible with the 1394. SIIG listed a few brand name companies like Sony and Canon (or whatever, I forgot). But as long as your camcorder is not made by John Dole then they chances are you can buy any combo card and you'll have a blast.
Originally posted by: Viper GTS
You specifically need a combo card?
