I need a replacement power supply for my Antec Overture II case. (SLP-450WR).
The problem is that the case is a desktop variant, not a tower, and the power supply sits on the bottom of the case, with the fan blowing down.
http://i.imgur.com/3D7Vy.jpg
This produces two problems, the first being is that the power supply is held in by 4 screws on the outside of the fan:
http://i.imgur.com/ESzB5.jpg
The other problem is that the power cable in, and power cable out are on the same side of the power supply.
I have contacted Antec on a recommended replacement, but haven't heard anything yet.
Can someone suggest a PSU that will work in this case?
