QueBert
I ordered the Coolermaster Geminii S524, but I'm having 2nd thoughts.
EVGA Hadron case
Asrock z77 iTX MB
Crucial Ballistix Elite memory - like 2.1" tall with spreader fins.
The case supports a cooler with a max height of 5.5 inches, I'm looking at the Noctua nh-u9b se2 right now. I'll need something that's less than 5.5" tall that won't cover my PCI-E slot or block the memory slot. It's air cooling so I have no budget here. I mean I don't want to spent $80 on something, but if there's a cooler that's quiet, cools well and costs $80 I would definitely consider it. It would be nice if it was something that didn't cover my memory so it can be seen thru the window, but ultimately that's not a huge concern. But if I can get everything in 1 cooler I'd definitely jump on that one.
I believe for the present I'll cancel the Geminii cooler order and just use a stock heatsink until I find something. iTX + this small case will make finding a good solution here tricky.
EVGA Hadron case
Asrock z77 iTX MB
