I want to find a good way to backup my personal data.
My main drive is an 80GB Maxtor with 19 Gigs of data to backup. I have access to a 30 gig drive on a networked computer, and I have a new 80GB drive in the box. My system is RAID capable and I am running Win2k.
If I install the 80GB drive, should I keep it unplugged, and only plug it in during a backup so that my data would be safe from a nasty virus? If I continue to use the networked 30gb drive, it may also be possibly exposed to a virus since the system is on and connected all the time. If I mirror RAID the 80GBs or use the network drive, I will be safe from physical failure, but is there still a small chance of losing everything, right?
Also, what I don't have is any backup software. I had been using Explorer copy and paste to copy my data, deleting the previous backup, and copying the current one (once I accidentally deleted my current data instead of the old backup, and lost a month of work). I have many files that don't change much such as mp3s. If i must backup manually, I usually only end up doing it once a month.
