Help me figure out this logic problem, it seems impossible~!
Cuda1447
11,757
Ok a basic run down of the problem.
You've got 5 people, they have to go across this bridge in 30 seconds. They need to go in ones or twos. They have to carry a lamp with them at all times when crossing the bridge. They must cross at the slowest one in the groups speed. They cross at these speeds
1 second
3 seconds
6 seconds
8 seconds
12 seconds
So logic would make you think have the 1 second guy go across with everyone and come back as fast as he could. But that doesn't work.
GoingUp
16,720
1 second
3 seconds
6 seconds
8 seconds
12 seconds
yea thats what I tried too....
Basilisk6
137
Hint: The trick to any bridge crossing problems like this is that you need to get the slowest people to go across together, effectively removing the second slowest person from the equation. I'll let you try it with that hint.
Cuda1447
11,757
still doesn't work! Just gimme the solution if your so smart lol
lozina
11,711
8
I've seen many of these type of problems. The trick is to take the two fastest guys across, one comes back with lamp. then the two slowest guys go accross, and the other fastest guy bring the lamp back. that move saves alot of time.
GoingUp
16,720
doesnt work
theApp
139
Spoiler:
First, send the 1 and 3 across. Send the 1 back. Send the 1 and the 6 across. Send the 1 back. Send the 12 and 8 across, and send the 3 back. Finally send the 3 and 1 across. Done in 29 seconds.
3 + 1 + 6 + 1 + 12 + 3 + 3 = 29
Basilisk6
137
doesnt work
Sure it does. Solution:
Send 1 and 3 (3 seconds)
Send 1 (4 seconds)
*Send 8 and 12 (16 seconds)*
Send 3 (19 seconds)
Send 1 and 6 (25 seconds)
Send 1 (26 seconds)
Send 1 and 3 (29 seconds)
And you're done with 1 second to spare.
Cuda1447
11,757
Ahh ok, I figured it out now. lol
Emveach
319
****SPOLIER*****
1) 1 and 3, send 1 back
2) 8 and 12, send 3 back
3)6 and 1, send 1 baclk
4)1 and 3.
Finish with 29 seconds.
GoingUp
16,720
got it!
send over 1 and 3, then send back 1, send over 8 and 12 then send back 3 send over 1 and 5 then send back 1 then send 1 and 3
