Help Me figure Out this Front panel Audio
QueZart
165
Here is the MB Manual
http://www.chaintech.com.tw/tw/eng/Download/dl_LI.asp?DISNo=659
I think the Header layout is on Page 10
The Wires I have in my case are Not Labeled anything like the Header Soo I cant figure it out
Hers the Wire I have
MIC VCC - Single Pin - No Clue where to put this
MIC Data - Single Pin - No Clue where to put this
Ear L - Single Pin /w a 2nd Pin coming of the same wire - I think these wil go on 9/10
Ear R - Single Pin /w a 2nd Pin coming of the same wire - I think these will go on 5/6
Any Input would be appreciated
MobiusPizza
2,001
Ear L would be across Front L and L
Ear R would be acorss Front R and R
MIC Data should go to the MIC
MIC VCC should go to X, or otherwise AGND
Just try and see which works
