The Stigenator
This problem cropped up sometime late last year. I had posted about it here... It was the car's coolant temprature that went up to half and then didnt go down. It stayed at 1/2 (which is not normal for my car under normal diriving conditions). Anyway back then I had noticed an increase in power too. I had given it for a serivice to Toyota and they found the problem with the "radiator cap" not pressurizing at higher tempratures. I also noticed after the service that the car was idling a lot higher than usual.. but the water temprature was its supposed to be and I really didnt care for the additional idle.
Now forward 4000 miles later and I gave my car for an oil change to jiffy lube. Today while waiting in line at the drive thru the water temprature went up to 1/2. But it was rather quickly. It never goes up in 5 minutes of driving. The needle came back down after I started driving again. When I got home I let it idle and noticed it was idling a lot higher than before jiffy lube looked at it. One thing is that car is running very smooth (engine) and the power deliever is smooth and ever so present. Infact it accelrates so fast that is frightning.
So here is the deal.. I have come up with possible areas that this idling problem could come from.
1. Oxygen sensor is bust
2. PCV valve possibly closed
3. Cat converter has something to do with it (well I know that needs replacedment soon).
4. Radiator cap needs replacement - will change that today.
The car is a 1994 Toyota Tercel with 126100 Miles or so. Its an EFI (Electronic Fuel Injection) model. Its been in good care for the most part, regular service and all. Though the cat converter does need work (I barely passed CA smog last time).. sometiwht with HydroCarbon and CarbonmonOxide being too high.
If I want to replace teh O2 sensor and the PCV valve myself.. how hard will that be? I will probably drop by Autozone to see if they got what I want. They also allow you to borrow the tools for a deposit.. its something simple as replacing my
Can you confirm if I am going the right direction.
