Help me decide which backup solution is best
chasem
Banned
Dec 17, 2001
705
On my customers computer, zip drives wont work, due to a driver issue.
I could format and redo it but that is out of the question
He is going to be backing up 230mb daily. it needs to take under 7 minutes to backup and the media needs to be very portable.
NO IOMEGA PRODUCTS PLZ
thx
John
Moderator Emeritus<br>Elite Member
Get a USB enclosure and slap a 24x10x40 CDRW in it.
RSMemphis
1,521
Flashmemory or Smartmedia with a card reader? You should be able to get them in 256 MB flavors.
7 minutes should be ok for 230 MB...
sanz
160
Another vote for 256MB USB Pendrive.
Got 128MB one here.. works great. No driver needed if the os is WinME/Win2k/WinXP
Cant beat the portability.
