help me decide please
cleonjr
this is my first computer build is this choice good
Computer Cases, ATX Form)
ANTEC SOLUTION SERIES MODEL SLK3700AMB w/ANTEC SMART POWER 350W P4/AMD POWER SUPPLY ATX12V - RETAIL
Offering a large 8-drive capacity in a convenient mid tower. This cost-effective new Super Mid Tower comes in an attractive color - Antec Metallic Bronze - with the features and quality you expect from Antec.
Specifications:
Driver Bays: External 4 X 5.25" - 2 X 3.5" (Tool-less Drive rail system for 5.25 Devices) - Internal 5 X 3.5" (Quick Release Drive cage for 3.5" Drive bays)
System Board: Standard ATX
Expansion Slot: 7 Slots
USB/IO: 2 X USB (front)
Optional Fans: 2 X 120mm (front & rear)
Case Dimensions: 18.6" (L) X 8.25" (W) X 18.3" (H) more info>
N82E16811129122 $73.00
►On Sale! Lite On 52x24x52 CDRW Model LTR-52246S Retail Buffer underrun error free & automatically adjust writing strategy plus running OPC to meet various burning condition.
Specifications:
Speed : Recording 52Xmax CAV Re-writing 24X High-Speed CLV Reading 52Xmax CAV
Interface : ATAPI-E/IDE, support up to Ultra-DMA Mode2 33.3MB/sec
Access Time : 80ms
Buffer Memory Size: 2MB
Operating System : Windows 95/98/NT/XP/2000/ME
Retail box, See pic for details more info>
N82E16827106184 $50.00
CD/DVD R/RW Media
Pengo CD-R Recordable Media Disk 50 Piece Pack OEM
Specifications:
Type: CD-R
Recording Speed: 48X
Capacity: 700MB
Recording time:80 Minutes
Coating:Silver
Shiney Surface Silkscreen & Thermal Printable Disc more info>
N82E16817131994 $15.00
CD/DVD ROM Drives
LITE-ON XJ-HD166S 16X DVD ROM Drive - Retail48X CD-ROM Access all format DVD-ROM/R/RW ,CD-ROM/R/RW title & disc Comes with Audio Cable, Manual and Power DVD Software. XJ-HD166S or, XJ-HD165H more info>
N82E16827131113 $35.00
Floppy Drives
MITSUMI D359M3 FDD 1.44MB 3.5INCH - OEM
Specifications:
Connector: 34-pin Floppy cable Standard Connector.
Modes: HD(1.44MB) Supports: Dos, Windows 3.1, 95/98 NT3.51 and 4.0
2DD(720kb) Supports: Dos, Windows 3.1, 95/98 NT3.51 and 4.0 more info>
N82E16821103104 $8.00
Hard Drives
WD WESTERN DIGITAL EIDE HARD DRIVE 120GB 7200RPM MODEL # WD1200BB -Caviar OEM, DRIVE ONLY
Specifications:
Size: 120 Gigabytes
Interface: IDE ULTRA ATA100
Seek time: 8.9ms
RPM:7200
Cache 2MB
OEM(Drive alone) 1 Year Manufacturer Warranty --* Works With PC & Mac *-- more info>
N82E16822144107 $125.00
Memory (System Memory)
CORSAIR MEMORY XMS Extreme Memory Speed Series 512MB 32MX8 PC-2700C2PT With Platinum - Silver Heat Spreader OEM
Specifications:
Speed 333 MHz
Organization 64M x 64
CAS Latency 2-3-3-6-T1
Memory type DDR
Part number: CMX512A-2700C2PT more info>
N82E16820145412 $102.00
Motherboards - Intel
ALBATRON INTEL 845PE Chipset ATX Motherboard Model PX845PEV PRO Retail **Highest FSB 667 (166Mhz), Memory Overclocking speed up to DDR439 Tested by Anandtech.com**
Specifications:
Hyper-Threading Technology
Supported CPU:Intel Pentium 4 Socket 478 Processor
Chipset:845PE/ICH4
FSB:400/533MHz
RAM:3 DDR333/266 Memory Sockets
IDE:2x ATA100 Channels, up to 4 IDE Devices.
Slots:5 x PCI 1x AGP
Ports:2xCOM,1xLPT,6 x USB2.0 , 2 x PS2, and Audio Ports
Onboard Sound: 6 Channel AC 97 Audio
Onboard LAN: 3Com 3C910-A01 LAN more info>
N82E16813170105 $81.99
$81.99
Processors
Intel Pentium 4 / 2.53GHz Northwood 512K Socket 478 Processor 533MHz Processor Bus
Specifications:
CPU: 2.53 GHz
Type: Pentium 4 Northwood
Cache: 512K
BUS: 533 Mhz
Socket: 478 Retail (Box with Heatsink and fan), 3-year MFG. Warranty-(CPU ONLY NO RAMBUS RAM) more info>
N82E16819116144 $187.50
Video Cards
SAPPHIRE ATI OEM RADEON 9500 PRO 128MB DDR DVI BULK
Specifications:
Chipset:ATI RADEON 9500 PRO
Memory:128MB DDR
Bus:AGP 8X 128-bit floating-point color precision allows for a greater range of colors and brightness
Memory Bandwidth: 2GB/Sec
Directx 9.0 Supported
Supports Modes SmartShader2.0 SmoothVision2.0 Truform 2.0 and much more
Ports:VGA + DVI + Svideo Out (s-video cable included) $181
Originally posted by: JohnnyTT
Hard Drive...... go with a JB Special Edition. It's only a few bucks more and well worth it.
Absolutely correct. Also, why are you paying $15 for Pengo CD-R's? Who the f*** are they?! I've never heard of them. I'm a big believer in quality CD-Rs, but that's just me. Do what you will.
I probably wouldn't get that vid card either, but that's just me.
Definatly go with the JB HDD. The Vid card is not bad at all 9500 Pro ROCKS!!!=). If you have a few more bucks to spare jump an a 9700 non-pro should overclock to pro speeds EZ.
what do think is a better choice for a vid card then?also pengo is quite good media never made a coaster yet
