Homerboy
Wife needs for a POS for his business.
I need for some other small applications/use.
Kids will tinker with it as well.
Most data will be through WiFi/hotspot except when wife using as POS at some conventions/shows.
These things are tricky....
You can get a BRAND NEW one for $630 through T-Mobile and that includes 200MB of data each month (more than enough for our needs)
Or you can get a used iPad 3 for $350 through various carriers with a data rate of $20-$15 a month ($240-$180 per year... total then is ~$600-$550 for the 1 year cost of the iPad)
Or you can get a used iPad 2 for $275 (though harder to find...) with the same data contacts per month as listed in for the iPad 3... so $525-$475 total 1 year cost.
It's like it's ALMOST better to buy a brand new one on TMobile, but the damned entry price is so steep!
