Help me decide on Sub $30 headphones!
PHiuR
9,539
right now im looking at either
Sennheiser HD-457 Ultra-light Supraural Headphones
or the Koss UR20
or Panasonic RP-HT660 Monitor Headphones with Auto Rewinding Cord
thanks!!! reply soon cause i want to order in less than 1 hour :)
dakata24
6,366
Koss UR20 Reviews
i actually have these.. they work good for its purpose (so i can hear footsteps in CS :p).. i'm no audiophile, so i don't have a clue as to if these are good.. i just got them because they were cheap. :)
PHiuR
9,539
thanks for the reply :) i think ill go and check out my local taget once my dad gets back :) and see if they have it! if they dont then ill just order it online somewhere
dakata24
6,366
i got mine at Target..
isnt the sennheiser overall supposed to be a good headphone brand though? wish i had auto rewinding cord for my headphones like the panasonic..
basara318
496
just cough up the extra buck and get the koss portapro for 31$ shipped from www.koss.com. there is a coupon floating around on the www.headwize.com msg boards for it. i got mine the other day and i am pleased with it. a bit muddier than my grado 60s but the bass is sweet and loww.. rawr!!
GoSharks
3,053
i would go for none of the above.
find some koss ksc-35 and buy those, or if you cant find those, get a set of ksc-50. they are basically the same thing, but the 35's have a more snug fit. best sounding for under $50
v-300's are no good compared to the 35's or the 50's
