Hello everyone!
Okay, I've narrowed down my DSLR search to these two very well regarded, extremely capable cameras. On the Nikon front, I like the metering system, the faster burst mode, HD-movie capability and the sheer number of lenses and accessories made for it. Nikon also has a greater dealer and support network.
As far as the Pentax, it has that HUGE CCD sensor, very well made and robust body with weather-sealing, effective dust control, image stabilization built into the body, on-board wireless flash operation and is anywhere bewteen $200 - $400 cheaper than the Nikon depending on how you buy it, ie. body only vs. kit form. Accessories and lenses, while fewer than the Nikon, seem to be lower priced as well.
I think the quality of both cameras is similar, as are the quality of the glass in their lenses.
Are there any opinions either way concerning these two DSLRs? Have any of you used them? What did you like or dislike?
Thanks for any thoughts or opinions!
Twitch
Twitch
