Here is the lineup:
Frontier Labs Nex IIe
e-digital Treo 10
e-digital mxp-100
MPIO DMG
Here's what I'm going to be using it for:
Running and working out in general
Commuting
Walking around campus
I won't be using the stock headphones so those don't matter. I'd like to get one for as cheap as possible so don't suggest an i-pod. Also, I don't want one that doesn't have the option to upgrade the memory capacity. I also need one that supports variable bit rate and up to 320kbps. I will be using Grado SR-60s and Koss KSC-35s as headphones. Optimally, the unit will have a powerful built-in amp and a high S/N ratio. The Intel Pocket Concert would fit that bill, but it doesn't allow extra memory. The MPIO looks like it has a pretty weak amp, but decent S/N ratio. I'm leaning towards solid-state memory because of running and such, but the Treo can store so much for around the same price.
e-digital Treo 10
e-digital mxp-100
MPIO DMG
Commuting
