I am looking to install a new video card on a Compaq Presario SR1610NX; it currently has ATI X200 onboard video...I am upgrading the PSU to handle any power needs...it has a S939 MB with 1.8GHz Sempron; 1.25GB RAM
I will be using this mostly for internet/web site work/home office...secondly image manipulation for photography, and some video editing (either pulling in VHS tapes to DVD or using my Firewire enabled DV camcorder)...finally I would like to be able to play with MS Flight Sim or X-Plane with no issues and good/decent frame rates.
Primary consideration: Must handle Dual Monitor (Both are 17" CRTs until they break or a massive sale goes on); Must use PCI-e slot; over clockable would be nice, but not required as long as the card performed well; would prefer not taking up two PCI slots.
What I have narrowed it to are the following cards from ATI that I have run across or have been suggested to me....some are 128Bit, some 256 bit; some are DDR2 others DDR3.....
I appreciate any suggestions you have...it can't be so easy as to choose the highest X####, then the highest bit rate, the highest VRAM and DDR type??
The X1600 at the top, then the 1300. then the x800 at the bottom...there is only $42 difference between the highest and lowest prices...thanks for any feedback and suggestions.
$155 - SAPPHIRE 100145L Radeon X1600PRO 512MB 256-bit GDDR2 PCI Express x16 Video Card - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16814102653
$134 - SAPPHIRE Radeon X1600 PRO 256MB PCI Express 100144 SAPPHIRE Radeon X1600PRO 256MB GDDR3 PCI Express x16 Video Card:
http://www.newegg.com/Product/Product.a...2650&CMP=OTC-pr1c3watch&ATT=14-102-650 (One Review indicating higher than expected fan noise)
$129 - SAPPHIRE 100144L (Retail) Radeon X1600PRO 256MB 128-bit GDDR2 PCI Express x16 Video Card - Retail
(http://www.newegg.com/Product/Product.asp?Item=N82E16814102651)
$113 - $123 Sapphire 100142 ATI Radeon X1300 512MB DVI/VGA/TV-Out PCI-Express Video Card
http://www.ewiz.com/detail.php?p=AT-X13005&c=pw or
http://www.newegg.com/Product/Product.a...2631&CMP=OTC-pr1c3watch&ATT=14-102-631
$124 - SAPPHIRE 100142L Radeon X1300 512MB 128-bit GDDR2 PCI Express x16 Video Card - Retail
http://www.newegg.com/Product/Product.a...2630&CMP=OTC-pr1c3watch&ATT=14-102-630
$148 - SAPPHIRE 100129FBL Radeon X800GTO 256MB 256-bit GDDR3 PCI Express x16 FireBlade Edition Video Card - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16814102660
$144 - SAPPHIRE 100129L Radeon X800GTO 256MB 256-bit GDDR3 PCI Express x16 Video Card - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16814102602
