Help me create Digital Audio CD-R
ERmergency
102
So I got this car with a PIONEER DEH-2100 CD Receiver. I found out that its playback compatible with Digital Audio CD-R (when disc is finalized).
So my question is: I have all these 128 Bit Rate 44kHz Audio sample rate MP3s, how do I burn them so there compatiable with my cd player?
Thanks
Frosty3799
3,795
both those programs will auto convert to .wav format if you make a cd under the audio option
EDIT: i think that would make digital audio anyway??
gopunk
29,239
yea what frosty said. choose audio cd when it asks you what you want, then drag and drop.
ERmergency
102
Thats all I have to do? Convert to wav? Do I need a special type of CD-R Media or anything else?
gopunk
29,239
<< Thats all I have to do? Convert to wav? Do I need a special type of CD-R Media or anything else? >>
you don't even have to convert it to wav, the prog. does it automatically for you :p
no, you don't need any special media, and do NOT buy the "audio cd-r's" the only difference between the "audio" and the normal ones is that the audio ones cost more because the record companies get a chunk of it. just make sure you get a decent brand (not some cheap generic one). one of the best ones are the ones made by taiyo yuden. TY is the factory, and they get rebranded. fujifilm uses them, i believe... they come in containers with a beige screw cap. made in japan.
Pepsei
12,895
the way i did it is to convert the mp3 to wav file first using dbamp, so i can normalize the volume on all the audio cds that i made.
drag and drop with nero. that's it.
